Altaer
May 30, 2025Guide
Orbi RBE771 Latency issues every 60 minutes
Ever since purchasing RBE771 back in October of 2024, I have dealt with an issue where every 60 minutes exactly on the dot my internet has super high latency for 30-60 seconds, and then returns back ...
Altaer
Jul 15, 2025Guide
No, I am still dealing with the issue. I am hoping to install the new Orbi firmware update when it becomes available to me within the web interface and will report back if it fixes the issue or not
Jul 15, 2025Guru - Experienced User
You have not updated the system manually yet?
- AltaerJul 15, 2025Guide
No, since I work from home and rely on internet for my job, I am hesitant to manually update firmware or try beta firmware.
- FURRYe38Jul 15, 2025Guru - Experienced User
I updated my 770 series using this process:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Fairly easy to follow. Maybe something to try on the weekend off work hours.
Mines been stable on this version of FW.
