B737Max's avatar
B737Max
Tutor
Dec 13, 2023
Orbi RBE971
My cell phone connects to Wi-Fi 6e and after a while switched to Wi-Fi 5g, I prefer the 6e, is there a way to setup the connection where my cell phone can always use 6e?
Thanks
  • FURRYe38's avatar
    What brand and model cell phone do you have?
    What OS version is to the cell phone?
    Its up to the wifi device to pick and choose which frequency it connects too.
    Does this happen with the RBS turned OFF?
    What channel configurations are currently set on the router?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Straq
    • B737Max's avatar
      B737Max
      Tutor
      Samsung Fold 4 and Samsun S-23
      on both we have android 13
      Robi Firmware Version
      V9.10.2.3_1.1.13
      Modem Netgear CM1000
      do not know what RBS is
      2.4 GHZ channel is Auto
      5.0 GHZ channel is 40
    • B737Max's avatar
      B737Max
      Tutor
      Thanks for your help I did the mac address, I will report after a few days, right now I am typing I am connected to 6E
