pwd5018
Oct 22, 2025Aspirant
Orbi satellite RBE370 is bricked
ok
pwd5018
For some reason the website was saying I had invalid HTML tags in my original message. Here it is..
I am not sure where else to send this, as the only phone number to contact anyone from netgear is through the support number. I have been through five different troubleshooting sessions with these guys and we keep going through the same steps. All I am requesting is a replacement orbi satellite so I can continue using the product as I originally intended. If I need to keep going through more troubleshooting sessions, I will be forced to request a refund for the entire product package, and a customer will be lost. This has been a terrible experience and I do not understand why I have to go through all this time to get a replacement. I have done all the common troubleshooting as well as more technical ones including running through the TFTP process in my attempt to update the firmware manually on the unresponsive device. Nothing has worked.
- FURRYe38Oct 23, 2025Guru - Experienced User
What FW version is on the RBR unit?
Try a factory reset on the RBS by pressing the rest button on the RBS for 15 seconds, then give 5 minutes and give this process a try to see if you can get to the RBS self service web page by following this guide: Orbi Satellite (RBS) Self-Service Web Page Access | NETGEAR Communities
If this fails try a 30-30-30 reset on the RBS.
If this all fails, you'll need to make contact with NG support and ask for an RMA.
- pwd5018Oct 23, 2025Aspirant
Fw version 12.1.3.11
I tried all those steps many times. When I call support, they refuse to provide am RMA because they seem to want to spend days with me trying to fix the issue. Everything I call it's a new person and they want to troubleshoot again. Same thing over and over and will not agree to just providing me a replacement.
K, will see if a moderator can help out.
