BVdG's avatar
BVdG
RB971 and 4 sats, installed on router a cooling fan ... router freeze
Exactly the same problem :  RB971 and 4  sats, installed on router a cooling fan ... router freeze, restarting, sats not connected (even they are wired with the best cat cable)...  more than 3k€ spend and nothing than problems :-( as you said this is frustrating
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How are the RBS connected to the RBR? Wireless or Ethernet?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    All Logging on the RBR, Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
  • plemans's avatar
    How old is this unit? Is it new? If so, return/exchange it. I've had my 973 since release and it hasn't frozen/overheated a single time and that's without a fan and over 100 devices connected
