ocnblue's avatar
ocnblue
Tutor
Oct 16, 2025
RBE771 Connection Constantly Dropping
I have an RBE771/RBE770 that I have had running for just under a year. My current setup I am using Ting and I get 2GB up/down.  They have a fiber modem which I run into the Orbi and I also have a NETGEAR 8-port 2.5G Multi-Gigabit Ethernet Plus Switch.
In the last month, I am getting 10-20 drops a day. I can't hit a website at all and everything comes to a grinding halt. Sometime the connection comes back after 3-5 minutes but lately I am just unplugging the Router to reboot it.
My firmware was current in the admin console but a Netgear search said the latest was V10.5.20.3 so I loaded that up about 4 days ago. No change on the drops at all.
I contacted Ting and they of course said everything was fine on their end. They show a solid connection and no errors.
Any suggestions on troubleshooting here? I will probably replace all cables this weekend for grins but this is nuts on a less than one year old Orbi Mesh system. My prior Orbi system was amazing for years but was limited to 1GB so I had to upgrade when Ting gave us 2GB. The logs I am looking at are basically worthless from the admin panel.  Just basic info and nothing isolating an error.
Appreciate any feedback!
  • CrimpOn's avatar
    CrimpOn
    It would help to have a detailed description of "drops".  i.e.
    • The WiFi signal disappears temporarily, or the WiFi signal does not disappear?
    • Both devices connected with Ethernet and devices connected via WiFi are affected?
    • When this happens every device connected to the system is affected the same way?
