Volvo3389's avatar
Volvo3389
Follower
Oct 12, 2026
RBR350 Not Connected in the App
Hi I have a RBR350 mesh setup, I have an issue now saying the router ( Orbi router ) is not connected in the app. But the sateelites are OK can anyone help ?Orbi map
  • I can log in on my laptop and it said my firmware was up to date I have had the set up for 5 years with little or no trouble
    I have restarted as per the above if I open the app I get the attached
    the WiFi network is all ok as well
    • FURRYe38's avatar
       Seems there maybe a FW update ready for you system...
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
      Be sure to disable any MAC Address randomizers on phones and pads while at home:
      NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
      Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
      Turn off and unplug modem.
      Turn on computers and rest of network.
  • FURRYe38's avatar
  • StephenB's avatar
    If the phone is connected to the Orbi wifi, then this has to be a an app issue.
    What do you see when you log into the Orbi web ui?
