bsniekers
Oct 04, 2025Follower
RBR760 wont fall back to wireless backhaul
my RBR760 and 3 satellites wont fall back to a wireless backhaul when one of the satellites loses it's wired connection; the satellites just goes offline instead which is not what I want; I would exp...
CrimpOn
Oct 04, 2025Guru - Experienced User
Orbi systems are designed to check the router to satellite connection using an internal timer and automatically switch to the best connection. This is why it takes a few minutes for the satellite to recognize that a 'wired' connection exists and switch to it.
Is it correct to assume that when the satellite is powered up when not 'wired' that it reports a Good 5G connection to the router on the Attached Devices web page?
The current firmware for the 760 system is v6.3.8.5. Is this the version running on the router and satellites?
One would imagine that this situation does not happen frequently, correct?
