bsniekers
Oct 04, 2025Follower
RBR760 wont fall back to wireless backhaul
my RBR760 and 3 satellites wont fall back to a wireless backhaul when one of the satellites loses it's wired connection; the satellites just goes offline instead which is not what I want; I would exp...
Oct 06, 2025Guru - Experienced User
Any progress on this?
Had the RBS been first setup and connnected wirelessly to the RBR then once all set there, then connect them to ethernet. Then once all settled in there, do a test by disconnecting one of the RBS from Ethernet and give 1-2 minutes to see if the status changes on the RBRs web page from wired to wireless status?
bsniekers wrote:my RBR760 and 3 satellites wont fall back to a wireless backhaul when one of the satellites loses it's wired connection; the satellites just goes offline instead which is not what I want; I would expect them to fall back to a wireless connection to keep the mesh network intact. To get the satellite back online, I need to give it a power cycle to then re-join the mesh.
How can I change my set-up so that the satellites DO fall back to a wireless backhaul?
