Remyh
Aug 05, 2026Tutor
Router works fine, but seems to have trouble finding the satellite
I did a manual update first on the satellite and later on the router. Router works fine, but seems to have trouble finding the satellite. Did a power cycle, tried a factory reset on the satellite, only restarted with a fixed blue light. It looks like it works, because reception near the satellite is good… but can’t access by ip or on the router page.
1 Reply
You have the 970 series?
Which browser did you use to manually update the system?
Did you factory reset the RBR as well as the RBS then setup from scratch? Follow this and it should help get the RBS working correctly:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
