jefferis
Mar 09, 2026Guide
Satellites for RBE771 connect but don't work
I have been fighting this problem for weeks. I have an Orbi 97 system RBE771 with 2 satellites. The computer connected directly to the Router via WiFi has great speed and the router itself te...
Mar 09, 2026Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How are the RBS connected to the RBR? You say via ethernet? Is this ethernet connection directly behind the RBR or is there some kind of LAN switch or LAN patch panel in between the RBR and RBS?
Brand and model# of the LAN switch if using one.
Connect on RBS directly behing the RBR with out any lan switch or patch panel in between to test connection behind the RBS with a wired PC.
Brand and model # of the ethernet adapter is this PC.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
