jefferis
Mar 09, 2026Guide
Satellites for RBE771 connect but don't work
I have been fighting this problem for weeks. I have an Orbi 97 system RBE771 with 2 satellites. The computer connected directly to the Router via WiFi has great speed and the router itself te...
jefferis
Mar 10, 2026Guide
Firmware Version
V10.5.20.7_2.2.48
The network equipment is Cambium (used to be Motorola - spun off). Radio Frequency from a Tower powered by Spectrum
The router goes from an ethernet cable to a patch panel for Cat 5. Don't see a brand.
The satellite in question is about 75 feet from the router (dashboard says the wired connection is good). Now, I had a second one in the opposite direction about 40 feet from the router with 1 wall in between connected via mesh. The problem with it was that if my laptop connected to it, the speed became glacial. When I turned it off and connected directly to the router, my speed returned to normal.
I have set channels as you have suggested.
It seems to me that the problem is some kind of communication problem between the router and its satellites. But rebooting all doesn't seem to fix it.
Mar 11, 2026Guru - Experienced User
jefferis wrote:It seems to me that the problem is some kind of communication problem between the router and its satellites. But rebooting all doesn't seem to fix it.
What speeds are you seeing when you connect your laptop directly to the cable(s) going between the router and the satellites?
