jefferis
Mar 09, 2026Guide
Satellites for RBE771 connect but don't work
I have been fighting this problem for weeks. I have an Orbi 97 system RBE771 with 2 satellites. The computer connected directly to the Router via WiFi has great speed and the router itself te...
jefferis
Mar 11, 2026Guide
Okay Test: Satellite 2 directly connected to Router via Ethernet about 25-30 feet away.
Laptop connected to:
- Ethernet to Satelite: 18 Mbps
- Wifi to RBS: 7.5 Mbps
- Turned OFF RBS and then connected
- Ethernet directly to RBR: 84 Mbps
- Wifi to RBR: 54 Mbps
So even though close and wired, the speed drop using a satellite is very bad. I had the laptop in the same location for all tests. And when the RBS was 50 feet away and only connected via WIFI Mesh to the RBR, if I connected to the RBS, my laptop speed dropped to stall speed.
I changed a cable in the distant RBR in the office as got 8Mbps via Ethernet So definitely a slowdown due to distance, but I used to get 50Mbps.
This Wfi 7 system was supposed to be an upgrade from my ORBI50 but while the router is great, the satellite system is much worse. It seems like too much congestion between the router and its satellites.
Any software setting that could cause this obstacle?
Mar 11, 2026Guru - Experienced User
What brand and model# is this PC your using?
What brand and model# is the ethernet and wifi adapter in this test PC your using?
What speeds do you pay for UP and Down from the ISP that you should be getting?
Are you seeing to spec speeds with a ethernet PC connected directly to the ISP modem there with out the RBR being online?
