jefferis
Mar 09, 2026Guide
Satellites for RBE771 connect but don't work
I have been fighting this problem for weeks. I have an Orbi 97 system RBE771 with 2 satellites. The computer connected directly to the Router via WiFi has great speed and the router itself te...
jefferis
Mar 11, 2026Guide
What brand and model# is this PC your using? MacBook Pro M4, MacBook Pro 2020, Mac Studio M1
What brand and model# is the ethernet and wifi adapter in this test PC your using? Direct Ethernet to Studio, Using an Anker USB C to Ethernet adapter when trying to connect directly.
What speeds do you pay for UP and Down from the ISP that you should be getting? 80 / 10
Are you seeing to spec speeds with a ethernet PC connected directly to the ISP modem there with out the RBR being online? Yes
What happens if you use the wireless backhaul to connect Satellite 2 to the RBR? Do you mean when RBS is connecting wirelessly only? As stated above, my speeds drop dramatically if I am connecting or try to connect to the RBS, even if I can get a throughput connection. The fact that my original set up in my house had the wireless RBS and my laptop not being able to pass through to the internet when connected to the RBS is what caused this whole investigation in the first place.
One possibility is that the ethernet backhaul is negotiating 2.5 gbps, but the cable actually can't carry that reliably. Even with a new Ethernet cable it should be able to connect at 2.5G but it does not.
- FURRYe38Mar 11, 2026Guru - Experienced User
What the USB adapter connecting at?
Does thie USB C to Ethernet adapter support up to 2.5Gb speeds?- jefferisMar 11, 2026Guide
USB adapter to Ethernet to RBR : 84 Mbps
I can't test it higher because my rural service max is 90 Mbps.
Note here, I am only using the adapter for testing purposes. My Mac Studio in the office where the speed is weaker is Ethernet port to Ethernet port with no adapter required.
And that is the connection rate seen at the RBR Show stat page or is this the speed test with the adapter? Connection rate differs and is only the connection between the adapter and the port in back of the RBR or RBS. We are looking for connection rate here. When connected at the RBR, the connection rate can be seen on the RBRs web page under Advanced tab/Internet Section/Show Stats.
The adapter may show connection rate as well on the Mac OS networking properties as well on the Advanced Tab I believe.
ANKR makes different adapters, some that only support 1000Mpbs and others that do support 2.5Gb Connection rates.
- donawaltMar 11, 2026Hero - Experienced User
FYI FURRYe38 jefferis the Anker USB C to Ethernet adapter is probably not enough info, as they have 1GB and 2.5GB adapters. I would ask for Model Number, and also on Macs, go to 'Apple logo top left -> About this Mac -> More Info -> System Settings-> Network - > USB connection -> Details button -> scroll to bottom, 'System Report' -> under Hardware, click on Ethernet and see what 'Maximum Link Speed' says.
Also in that same section, what is the Vendor Name (mine is Realtek) and Product ID (mine is 0x8157)? I ask these because there have been some issues with certain chipsets - probably not in play here, but just in case.
These are the stats for the last 4 days I note I could set an advanced backhaul to 240Mhz but not sure if that would help between the RBS and RBR
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN 1000M/Full 130180864 121043799 0 8664 9376 4 days 03:36:07 LAN1 1000M/Full 12925731 9726595 0 10448 8138 4 days 03:36:07 LAN2 10M/Full 08:20:32 LAN3 100M/Full 08:18:40 2.4 GHz WLAN b/g/n/ax/be 688.2M 88093811 95518624 0 3562 4659 4 days 03:37:13 5 GHz WLAN a/n/ac/ax/be 2882.5M 23208336 27682855 0 1999 5743 4 days 03:37:13 6 GHz WLAN a/n/ac/ax/be 5765M 569993 227070 0 108 349 4 days 03:37:13 2.4 GHz WLAN Backhaul 688.2M 150369 82602 0 144 47 4 days 03:37:13 5 GHz WLAN Backhaul 2882.5M 281970 107768 0 100 61 4 days 03:37:13 6 GHz WLAN Backhaul 5765M 0 0 0 0 0 4 days 03:37:13
Anker USB C to Ethernet Adapter, Portable USB C Type-C 1-Gigabit Network Hub, 10/100/1000 Mbps,Network Adapter for MacBook Pro, iPad Pro 2019/2018, ChromeBook, XPS, Galaxy S9/S8, and More
Ok so this adapter you have is only 1000Mpbs so you won't see 2.5Gb connection rates at the RBR or RBS.
However you should see your ISP speed at the RBR and RBS at around 80-90mpbs which you said you do at the RBR.
Now connecting at the RBS, if you had the RBS ethernet directly connected behind the RBR near 25-30 feet distance and the adpter connected behind the RBS, you should see same speeds where with the adapter and PC. If the RBS was wireless connected instead of ethernet to the RBR, should see same speeds with the RBS at 30feet distance. If your not, possible this RBS could be faulty.
You only have one RBS currently?
- StephenBMar 11, 2026Guru - Experienced User
In your case, I am worried about the cable that runs between the RBR and Satellite 2. Which I don't think you've changed.
I mean disconnecting the ethernet cable that runs between the RBR and Satellite 2, and connecting the laptop to one of the satellite LAN ports. I haven't seen any reports here that suggested you'd tried that. Your initial post said the dashboard said the satellite was connected with ethernet.
- jefferisMar 12, 2026Guide
Okay, So I disconnected the RBS 2 and connected the laptop to it using ethernet and adapter and got 45 Mbps which is roughly the same speed I get via wifi connected directly to the RBR
- FURRYe38Mar 12, 2026Guru - Experienced User
Ok so If you directly ethernet connect ONE RBS behind the RBR and ethernet connect your adapter behind the RBS, what speed is seen here?
