jefferis
Mar 09, 2026Guide
Satellites for RBE771 connect but don't work
I have been fighting this problem for weeks. I have an Orbi 97 system RBE771 with 2 satellites. The computer connected directly to the Router via WiFi has great speed and the router itself te...
Mar 11, 2026Guru - Experienced User
What the USB adapter connecting at?
Does thie USB C to Ethernet adapter support up to 2.5Gb speeds?
jefferis
Mar 11, 2026Guide
USB adapter to Ethernet to RBR : 84 Mbps
I can't test it higher because my rural service max is 90 Mbps.
Note here, I am only using the adapter for testing purposes. My Mac Studio in the office where the speed is weaker is Ethernet port to Ethernet port with no adapter required.
- FURRYe38Mar 11, 2026Guru - Experienced User
And that is the connection rate seen at the RBR Show stat page or is this the speed test with the adapter? Connection rate differs and is only the connection between the adapter and the port in back of the RBR or RBS. We are looking for connection rate here. When connected at the RBR, the connection rate can be seen on the RBRs web page under Advanced tab/Internet Section/Show Stats.
The adapter may show connection rate as well on the Mac OS networking properties as well on the Advanced Tab I believe.
ANKR makes different adapters, some that only support 1000Mpbs and others that do support 2.5Gb Connection rates.
