jefferis
Mar 09, 2026Guide
Satellites for RBE771 connect but don't work
I have been fighting this problem for weeks. I have an Orbi 97 system RBE771 with 2 satellites. The computer connected directly to the Router via WiFi has great speed and the router itself te...
Mar 11, 2026Guru - Experienced User
What the USB adapter connecting at?
Does thie USB C to Ethernet adapter support up to 2.5Gb speeds?
jefferis
Mar 11, 2026Guide
Anker USB C to Ethernet Adapter, Portable USB C Type-C 1-Gigabit Network Hub, 10/100/1000 Mbps,Network Adapter for MacBook Pro, iPad Pro 2019/2018, ChromeBook, XPS, Galaxy S9/S8, and More
- FURRYe38Mar 11, 2026Guru - Experienced User
Ok so this adapter you have is only 1000Mpbs so you won't see 2.5Gb connection rates at the RBR or RBS.
However you should see your ISP speed at the RBR and RBS at around 80-90mpbs which you said you do at the RBR.
Now connecting at the RBS, if you had the RBS ethernet directly connected behind the RBR near 25-30 feet distance and the adpter connected behind the RBS, you should see same speeds where with the adapter and PC. If the RBS was wireless connected instead of ethernet to the RBR, should see same speeds with the RBS at 30feet distance. If your not, possible this RBS could be faulty.
You only have one RBS currently?
