Ctuck's avatar
Ctuck
Satellites stop working and WiFi is offline but wired still works
Mine is just going offline completely. Satellites stop working and WiFi is offline but wired still works. Annoying considering returning and going another route. Less than a week old and already having issues.
  • FURRYe38's avatar
    Do the front LEDS turn on PINK when this happens?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
  • FURRYe38's avatar
    Any progress on this?
