Oct 12, 2023Guru - Experienced User
Share your Orbi BE370/770/870/970 Series System UpTime
Found on the RBR and RBS IP address/debug.htm web page for best details, please post both RBR and RBS uptime. Please note of any inconsistencies between the RBR and RBS. Generally the RBR and RBS uptime should be same. Home wide power brown outs should be noted if these are seen.
Thank you.
OK, for the 770 series on newest v10.5.19.5 FW loaded, 10 plus days of uptime and good operation:
RBS1:
RBS2:
IPv6 disabled since ISP doesn't support it.
CAX80 gateway in modem mode.
RBS Wireless connected to RBR.
Manual channels 1 and 40.
System was updated manually, factory reset and setup from scratch then put online.
14+ days of good up time on v10.5.20.4 FW on a 870 series:
Basic Infomation
SeAL
v2.1.10.13-0
Armor-bd
v2.2.214.4
Spc-circle
v3.32.0.4
guster
v1.0.0.2049
CPU Load
15.74%
Memory Usage(Used/Total)
604MB/1828MB
Flash Usage(Used/Total)
758MB/3728MB
Network Session(Active/Total)
0/0
System Uptime
14:13:44:40
