Oct 12, 2023Guru - Experienced User
Share your Orbi BE370/770/870/970 Series System UpTime
Found on the RBR and RBS IP address/debug.htm web page for best details, please post both RBR and RBS uptime. Please note of any inconsistencies between the RBR and RBS. Generally the RBR and RBS uptime should be same. Home wide power brown outs should be noted if these are seen.
Thank you.
14+ days of good up time on v10.5.20.4 FW on a 870 series:
Basic Infomation
SeAL
v2.1.10.13-0
Armor-bd
v2.2.214.4
Spc-circle
v3.32.0.4
guster
v1.0.0.2049
CPU Load
15.74%
Memory Usage(Used/Total)
604MB/1828MB
Flash Usage(Used/Total)
758MB/3728MB
Network Session(Active/Total)
0/0
System Uptime
14:13:44:40
OK, for the 770 series on newest v10.5.19.5 FW loaded, 10 plus days of uptime and good operation:
RBS1:
RBS2:
IPv6 disabled since ISP doesn't support it.
CAX80 gateway in modem mode.
RBS Wireless connected to RBR.
Manual channels 1 and 40.
System was updated manually, factory reset and setup from scratch then put online.
- Chuck_MMentor
RBR 970 In Access Point Mode:
Basic Information
Firmware Version: V9.13.1.2_1.3.24
Boot Loader Version: 2016.01_rtm-9.6.0.2
seal: v2.2.6-0-g7fde0b86
armor-bd: v2.2.214.4
spc-circle: v3.32.0.4
guster: v1.0.0.2049
CPU Load: 12.14%
Available Memory/Total Memory: 1150 MB/1743 MB
System Uptime: 0 days 01:21:13
Server Information
Router Analytics: PROD
CHP Cloud: PROD
XCloud: PROD
BD Cloud:
Circle Cloud: N/A
AnalyticOptinOptout: Enable
Sat 1
Basic Information
Firmware Version :V9.13.1.2
CPU Load :11.44%
Memory Usage(Used/Total) :626 MB/1743 MB
System Uptime :16 days 14:30:21
Hop Count :1
Bootloader Version :U-Boot 2016.01_rtm-9.6.0.2 (May 27 2023 - 00:22:49 +0000)
Sat 2
Basic Information
CPU Load :10.91%
Memory Usage(Used/Total) :596 MB/1743 MB
System Uptime :5 days 0:47:0
Hop Count :1
- superuser79Initiate
Router
guster: v1.0.0.2049
CPU Load: 4.60%
Available Memory/Total Memory: 1084 MB/1743 MB
System Uptime: 8 days 17:04:22
SAT1
Basic Information
Firmware Version : V9.13.1.2
CPU Load : 11.22%
Memory Usage(Used/Total) :593 MB/1743 MB
System Uptime :8 days 17:1:32
Hop Count :1
SAT2
Basic Information
CPU Load : 11.66%
System Uptime :8 days 17:2:9
Hop Count :1
- TC_in_MontanaVirtuoso
Almost at 30 days (tomorrow will be 30) under 9.13.1.2
Pretty consistent - no memory creep, no drops, no reboots.
No IPv6, no Apple devices, satellites are connected via WiFi.
Router Debug Screen Information
Device: RBE971 WiFi Access Point
guster: v1.0.0.2049
CPU Load: 4.80%
Available Memory/Total Memory: 1052 MB/1743 MB
System Uptime: 29 days 00:47:14
Satellite Debug Screen Information for Satellite # 1
IP Address is: 192.168.1.101
Device: RBE970
CPU Load :11.24%
Memory Usage(Used/Total) :605 MB/1743 MB
System Uptime :29 days 0:47:48
Hop Count :1
Satellite Debug Screen Information for Satellite # 2
IP Address is: 192.168.1.102
Device: RBE970
CPU Load :9.14%
Memory Usage(Used/Total) :600 MB/1743 MB
System Uptime :29 days 0:48:8
Hop Count :1
********************************************************************************************************************************* - wvkregtenLuminary
System Uptime: 18 days 05:00:45
Which model system do you have and what FW version?
So 8 plus days ago, my system was updated to v9.13.1.2.
Only a power cycle OFF then back ON after FW had been updated via AU.
RBS wirelessly connected. Will test Ethernet next.
Router:
RBS1:
RBS2:
All seems to be working well so far.
So 16 plus days of good up time:
RBR:
DR RBS1:
NOTE: Uptime is off due to a user power cycle needed after RBS was wirelessly connected then being ethernet connected, the RBR UI and orbi app failed to update the status from MLO wireless to WIRED. Uptime was same as RBR and other RBS prior to this. Troubleshooting step was to power cycle the RBS OFF and ON and then status updated to WIRED.
BM RBS2:
19 plus days of good uptime on my 973 series:
RBS1 is 11 days as following by the power cycle then:
RBS2 at 19 days as well:
The 970 series has been taken off line today due to other testing needs on a different system.
Posting this here to get a beginning base line for the 970 series going online yesterday:
RBR:
Firmware Version: V9.12.5.3_1.3.24
seal: v2.1.10.8-0
guster: v1.0.0.2049
CPU Load: 6.05%
Available Memory/Total Memory: 1098 MB/1743 MB
System Uptime: 1 days 02:24:25
RBS:
Basic Information
Firmware Version :V9.12.5.3
CPU Load :11.55%
Memory Usage(Used/Total) :599 MB/1743 MB
System Uptime :1 days 2:55:0
Hop Count :1
CPU Load :11.49%
Memory Usage(Used/Total) :603 MB/1743 MB
System Uptime :1 days 2:57:21
Hop Count :1
Both RBS are wirelessly BH.
3 plus days up time on the 973 system:
RBS1:
RBS2:
- Chuck_MMentor
Basic Information
seal: v2.1.10.8-0
guster: v1.0.0.2049
CPU Load: 13.23%
Available Memory/Total Memory: 1137 MB/1743 MB
System Uptime: 23 days 00:46:59
RBE970Orbi SatelliteBasic InformationFirmware Version :V9.12.5.3CPU Load :11.28%Memory Usage(Used/Total) :679 MB/1743 MBSystem Uptime :23 days 0:49:18Hop Count :1Bootloader Version :U-Boot 2016.01_rtm-9.6.0.2 (May 27 2023 - 00:22:49 +0000)RBE970Orbi SatelliteBasic InformationFirmware Version :V9.12.5.3CPU Load :11.68%Memory Usage(Used/Total) :621 MB/1743 MBSystem Uptime :23 days 0:50:7Hop Count :1Bootloader Version :U-Boot 2016.01_rtm-9.6.0.2 (May 27 2023 - 00:22:49 +0000) Updated results with most recent Firmware:
RBE971 Router:Firmware Version: V9.10.2.3_1.1.13
Boot Loader Version:2016.01_rtm-9.6.0.2
seal: v2.1.8.24-0
armor-bd: v2.2.184.2
spc-circle: v3.31.1.2
CPU Load: 6.84%
Available Memory/Total Memory:1090 MB/1743 MB
System Uptime:5 days 12:01:03
RBE970 Satellite:
Firmware Version :V9.10.2.3CPU Load :8.86%Memory Usage(Used/Total) :625 MB/1743 MBSystem Uptime :5 days 19:47:8Hop Count :1Bootloader Version :U-Boot 2016.01_rtm-9.6.0.2 (May 27 2023 - 00:22:49 +0000)- FURRYe38Guru - Experienced User
As of yesterday:
Basic Information
seal: v2.1.8.24-0
CPU Load: 3.61%
Available Memory/Total Memory: 1127 MB/1743 MB
System Uptime: 10 days 03:50:54
