Oct 12, 2023Guru
Share your Orbi BE770/870/970 Series System UpTime
Found on the RBR and RBS IP address/debug.htm web page for best details, please post both RBR and RBS uptime. Please note of any inconsistencies between the RBR and RBS. Generally the RBR and RBS uptime should be same. Home wide power brown outs should be noted if these are seen.
Thank you.
Is this what you are looking for?
RBE970 Satellite 0 days 7:33:39
RBE971 Router 15 days 06:07:10
Firmware: V9.10.0.2_1.1.5
- Dfran1ApprenticeOrbi 790 system
Main and both satellites
Firmware Version :
V9.10.0.2
CPU Load :
8.75%
Memory Usuage(Used/Total) :
1530 MB/1743 MB
System Uptime :
21 days 1:55:1
The only weird thing is the memory usage on main and one satellite is what I posted using 3/4 of memory
BUT other satellite is using 1/3 of memory
Otherwise rock solid, absolutely no issues, and armor is still working amazingly, to me great. Updated results with most recent Firmware:
RBE971 Router:Firmware Version: V9.10.2.3_1.1.13
Boot Loader Version:2016.01_rtm-9.6.0.2
seal: v2.1.8.24-0
armor-bd: v2.2.184.2
spc-circle: v3.31.1.2
CPU Load: 6.84%
Available Memory/Total Memory:1090 MB/1743 MB
System Uptime:5 days 12:01:03
RBE970 Satellite:
Firmware Version :V9.10.2.3CPU Load :8.86%Memory Usage(Used/Total) :625 MB/1743 MBSystem Uptime :5 days 19:47:8Hop Count :1Bootloader Version :U-Boot 2016.01_rtm-9.6.0.2 (May 27 2023 - 00:22:49 +0000)As of yesterday:
Basic Information
Boot Loader Version: 2016.01_rtm-9.6.0.2
seal: v2.1.8.24-0
CPU Load: 3.61%
Available Memory/Total Memory: 1127 MB/1743 MB
System Uptime: 10 days 03:50:54
- Chuck_MMentor
Basic Information
RBE971 WiFi Access Point
Firmware Version: V9.12.5.3_1.3.24
seal: v2.1.10.8-0
armor-bd: v2.2.214.4
spc-circle: v3.32.0.4
guster: v1.0.0.2049
CPU Load: 13.23%
Available Memory/Total Memory: 1137 MB/1743 MB
System Uptime: 23 days 00:46:59
RBE970Orbi SatelliteBasic InformationFirmware Version :V9.12.5.3CPU Load :11.28%Memory Usage(Used/Total) :679 MB/1743 MBSystem Uptime :23 days 0:49:18Hop Count :1Bootloader Version :U-Boot 2016.01_rtm-9.6.0.2 (May 27 2023 - 00:22:49 +0000)RBE970Orbi SatelliteBasic InformationFirmware Version :V9.12.5.3CPU Load :11.68%Memory Usage(Used/Total) :621 MB/1743 MBSystem Uptime :23 days 0:50:7Hop Count :1Bootloader Version :U-Boot 2016.01_rtm-9.6.0.2 (May 27 2023 - 00:22:49 +0000) Posting this here to get a beginning base line for the 970 series going online yesterday:
RBR:
seal: v2.1.10.8-0
guster: v1.0.0.2049
CPU Load: 6.05%
Available Memory/Total Memory: 1098 MB/1743 MB
System Uptime: 1 days 02:24:25
RBS:
Basic Information
CPU Load :11.55%
Memory Usage(Used/Total) :599 MB/1743 MB
System Uptime :1 days 2:55:0
Hop Count :1
CPU Load :11.49%
Memory Usage(Used/Total) :603 MB/1743 MB
System Uptime :1 days 2:57:21
Hop Count :1
Both RBS are wirelessly BH.
3 plus days up time on the 973 system:
RBS1:
RBS2:
So 8 plus days ago, my system was updated to v9.13.1.2.
Only a power cycle OFF then back ON after FW had been updated via AU.
RBS wirelessly connected. Will test Ethernet next.
Router:
RBS1:
RBS2:
All seems to be working well so far.
So 16 plus days of good up time:
RBR:
DR RBS1:
NOTE: Uptime is off due to a user power cycle needed after RBS was wirelessly connected then being ethernet connected, the RBR UI and orbi app failed to update the status from MLO wireless to WIRED. Uptime was same as RBR and other RBS prior to this. Troubleshooting step was to power cycle the RBS OFF and ON and then status updated to WIRED.
BM RBS2:
19 plus days of good uptime on my 973 series:
RBS1 is 11 days as following by the power cycle then:
RBS2 at 19 days as well:
The 970 series has been taken off line today due to other testing needs on a different system.
