notCB
Aug 01, 2026Aspirant
Two devices can't ssh or ping
I have two devices, a Mac and a raspberry pi, that are connected to the same orbi satellite on the same main wifi ssid and same subnet using DHCP. The Mac is connected at 6Ghz and the pi is connected...
notCB
I have RBE971 and RBE970 with firmware V12.1.10.12_5.3.16. Have not tried disconnecting the satellite to connect to the router. Currently testing with the Mac hardwired to the satellite. The mac is using private wifi addressing (MAC address randomization). I can turn that off as the next test. Also, while the problem was occurring, I tried flushing arp cache on both devices and also rebooting both. That did not help.
My Sony TV and a few other devices randomly loses their wireless network connection. Not sure if that is related. Have not had the time to study it.
By the way, I have a fair amount of experience in networking and software development. As far as i can tell right now, this setup should work and it does work for a few hours.
Thanks.
Aug 01, 2026Guru - Experienced User
What channels are you using on the RBR? Try 1 and 40 or 11 and 48.
Distnace between the RBR and RBS? 30 feet is starting distances between them or more.
Size of home in sq feet please.
Your FW is behind by one rev:
Orbi Firmware Releases | NETGEAR Communities
You might update the RBS first, then RBR lastly, power OFF then back ON and try again. Use this guide to help you update:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
