Jmesparza05's avatar
Dec 12, 2024
Why can't I see 6ghz on my Orbi 970
Why can't I see the 6ghz on my Orbi 970?
It claims it has it but I don't see it anywhere in my orbilogin.
  • plemans's avatar
    1. what device do you have that you're looking for 6ghz? Do you have a scanner that picks up 6ghz?
    2. the orbi's combine the ssid's. So they don't appear separate.
    3. go to your advanced tab and then look at the "wireless settings" box. That will show you the bands. there isn't anything user modifiable for 6ghz
    • Jmesparza05's avatar
      Jmesparza05
      Tutor
      I have the S24 Ultra but idk if my router being connected to a non 6ghz has anything to do with it.
      • plemans's avatar
        Has anything to do with what?
        I'm still a little confused about whats going on exactly for you.
        A little better description would help.
