NG7856
Aug 22, 2026Guide
Why doesn't Netgear sell replacement 100V-240V 50/60hz ORBI 19V/3.16A power supplies
As the world grows smaller one important item when buying electronic equipment is the power supply converter (AC-DC). I looked at Netgear's information on the Orbi 970 but one important informa...
- Aug 23, 2026
NG7856 wrote:
We have read many community articles that the only difference is the power supply
Not the case. While the hardware itself likely is the same, the WiFi power limits are different (higher) in the US. So while the router will work, it will not be in conformance with EU regulations.
This is handled by region-locking the firmware - I don't believe there is any way change the region in Netgear's AX (WiFi 6)and BE (WiFi 7) routers.
NG7856
Aug 23, 2026Guide
I am looking for AC/DC power supplies for my Orbi 970 satetille.
RBKE973 332-11724-01 with plug adapters 19V/3.42A 100-240v 50/60Hz
or 332-10636-01 AD2003000
I would like Netgear with the compact slim fit.
- HappyCatAug 23, 2026Virtuoso
As you have no doubt discovered, Netgear does not sell individual power adapters. There are numerous brands available on Amazon claiming compatibility.
