MNOTCMH
Oct 05, 2026Follower
WiFi constantly dropping
I have the RBE371 and two satellites that is pretty much useless. I had zero issues with the older version but I cannot get a stable connection on this new system. Constant freezing or just completely dropping the connection. Seeing a lot of posts about this but past the return date. Any ideas or anyone found a solution. This is worse than not having WiFi.
1 Reply
Is this happening with the router? Or just the satellites?
Try turning off the satellites for a while if you are unsure.
