MNOTCMH
Oct 05, 2026Follower
WiFi constantly dropping
I have the RBE371 and two satellites that is pretty much useless. I had zero issues with the older version but I cannot get a stable connection on this new system. Constant freezing or just completely dropping the connection. Seeing a lot of posts about this but past the return date. Any ideas or anyone found a solution. This is worse than not having WiFi.
- FrumpyGrandpaApprentice
Has the system done this since it was first installed, or did it function correctly until recently?
Is this happening with the router? Or just the satellites?
Try turning off the satellites for a while if you are unsure.
