captainflicky's avatar
Apr 27, 2026
Wifi Drops my printer within minutes
I have a new Orbi 770 mesh. 50 plus devices running on the network but my brother printer HL-L2370DW constantly drops offline. I have updated all firmware on printer and orbi devices. I have rebooted the Orbi mesh and printer several times. I set up a static IP of 192.168.1.2 for the printer, which shows up on Orbi for a few minutes but as soon as I boot up my printer I have only minutes of use, then it drops off line. I have attached screen shot of the issue. Please help.
  • FURRYe38's avatar
    Is this the only device having this issue?
    Is this static IP address a IP address reservation on the RBR?
    Is the printer wireless or ethernet connected?
    is the printer connected to the RBR or to an RBS?
    How many RBS are deployed?
    What is the distance between the router πŸ“‘ and satellite(s)πŸ›°οΈ? 30 feet or more is recommended in between RBR πŸ“‘ and RBS πŸ›°οΈ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite β€Œβ€ŒπŸ›°
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
    Try connecting the printer ot the IoT network SSID configuration.
  • Is this the only device having this issue?
    The Sonos was having issues with the new mesh until I added a booster to the system and hard wired it to the network. There are about 50 other devices all using the IoT network without any issues for about 4 weeks now. Just the brother printer is the only system that drops offline.
    I went into "advanced->static routes-> and made a reservation for the printer through the Orbi web access portal. but the "destination" keeps changing to 192.168.1.0 but i told the printer to use 192.168.0.2. Not sure why Orbi keeps changing it?
    Wireless to the -IoT network.
    When I can see it, it appears to be connect to RBS. But it drops so quickly it rarely shows up on the list of devices.
    On the Orbi 770 mesh: V10.5.20.10_2.2.51 and it says 'no new firmware available' through the web access portal.
    Brother HL-L2370DW series: firmware 1.82
    Xfinity Gateway modem, set to bridge mode. XB8-T
    TWO, 1 is upstairs about 25 feet from router, the other is in the detached garage about 40 feet away.
    2000 ft + a detached garage.
    What is the distance between the router πŸ“‘ and satellite(s)πŸ›°οΈ? 30 feet or more is recommended in between RBR πŸ“‘ and RBS πŸ›°οΈ to begin with depending upon building materials when wired or wirelessly connected. https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite β€Œβ€ŒπŸ›°
    <30 ft . Good signal reported through orbi app near printer.
    Unplugged both satellites to test. The printer does not show up under Orbi web portal -> Advanced -> Admin -> attached devices. It's just NOT there at all. Then I'll refresh and it'll be there listed under 192.168.1.2. Then few minutes later it's not longer on the list of attached devices.
    However, when I ping 192.168.1.2 in a web browser I can talk to the printer. Until it drops off line... which is typically 3 to 5 minutes after re-booting printer.
    **Seems much more stable now that I have removed the satellites from the picture. But after 30 minutes It still dropped offline, and I was unable to ping the printer via a web browser at 192.168.1.2. Rebooting the printer fixes the issue.
    Just the printer drops wifi, but I have not tried to hardwire the printer.
    2.4 manually set to channel 1 (IoT set to 2.4 only)
    5 and 6 GHz set to AUTO
    Try disabling the following and see: Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
    All these were already disabled during my trouble shooting process.
    Try connecting the printer to the IoT network SSID configuration.
    The printer has always been connected to the IoT network. Which is set 2.4 GHz only.
    • FURRYe38's avatar
      Static Routes should not be used for the printer. Not needed or required. Remove this configuration.
      Make sure the printer is set for DHCP/Dynamic IP address configuration.
      Try connecting the printer to the main wireless network as well.
      For that size of home, the RBR unit and just one RBS satellite is enough.
      25 feet is too close between the RBR and this closer RBS. Try the RBS out at 30 feet or a bit more.
      Try connecting the printer over ethernet as I believe the printer has a ethernet port.
      Make contact with the printer Mfr as well since this is there product and seems to be the only device having issues.
      • krgoodwin's avatar
        krgoodwin
        Guide
        Regarding Furrye38's response - excellent suggestions.  In my long experience and especially in today's network environment, I have found static addresses to be nothing but problems and avoid at all possible costs using them - if feasible.  However, the days of hard wired connections is dying in the personal network environment.  Reserved DHCP addresses are another topic but I am using that less and less also.  "I am from DHCP and I am here to help you" - lol.
        Good possibility that you're using a cell phone to interface with your network (another thing I avoid at all costs preferring to use ethernet cable if possible).  If so, have you disabled randomized addresses on your cell phone or wireless device?  All the experts including FURRYe38 tell me Netgear has a problem dealing with randomized addresses and makes for dropped wireless connections. (Which when you think about it is completely counter to using static addresses.)
    • StephenB's avatar
      You might be confusing "static route" with "static address".  There is no need to create a static route for a reserved IP address - and if you don't know what you are doing you can really mess up your network routing.  You reserve an IP address on the advanced->LAN Setup page.
      FWIW, a static route is used to tell the router how to reach a network it otherwise doesn't know how to reach.  That is, a different subnet.
  • Ok, I have changed the printer settings to DHCP. I will  attempt to wire it into the router if it fails again to help with trouble shooting. thanks
      • captainflicky's avatar
        captainflicky
        Under orbi web app i went to advanced -> LAN and set starting ip 004-254. Then made an address reservation for the printer 192.168.1.2
        then went into the printer web app and set the ip to the same 192.168.1.2
        seems to be more stable in this configuration?
