captainflicky
Apr 27, 2026Aspirant
Wifi Drops my printer within minutes
I have a new Orbi 770 mesh. 50 plus devices running on the network but my brother printer HL-L2370DW constantly drops offline. I have updated all firmware on printer and orbi devices. I have rebooted the Orbi mesh and printer several times. I set up a static IP of 192.168.1.2 for the printer, which shows up on Orbi for a few minutes but as soon as I boot up my printer I have only minutes of use, then it drops off line. I have attached screen shot of the issue. Please help.
- captainflickyAspirant
Ok, I have changed the printer settings to DHCP. I will attempt to wire it into the router if it fails again to help with trouble shooting. thanks
Is this the only device having this issue?
The Sonos was having issues with the new mesh until I added a booster to the system and hard wired it to the network. There are about 50 other devices all using the IoT network without any issues for about 4 weeks now. Just the brother printer is the only system that drops offline.
Is this static IP address a IP address reservation on the RBR?
I went into "advanced->static routes-> and made a reservation for the printer through the Orbi web access portal. but the "destination" keeps changing to 192.168.1.0 but i told the printer to use 192.168.0.2. Not sure why Orbi keeps changing it?
Is the printer wireless or ethernet connected?
Wireless to the -IoT network.
is the printer connected to the RBR or to an RBS?
When I can see it, it appears to be connect to RBS. But it drops so quickly it rarely shows up on the list of devices.
On the Orbi 770 mesh: V10.5.20.10_2.2.51 and it says 'no new firmware available' through the web access portal.
Brother HL-L2370DW series: firmware 1.82
Xfinity Gateway modem, set to bridge mode. XB8-T
How many RBS are deployed?
TWO, 1 is upstairs about 25 feet from router, the other is in the detached garage about 40 feet away.
2000 ft + a detached garage.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected. https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
<30 ft . Good signal reported through orbi app near printer.
Does this happen with the RBS turned OFF?
Unplugged both satellites to test. The printer does not show up under Orbi web portal -> Advanced -> Admin -> attached devices. It's just NOT there at all. Then I'll refresh and it'll be there listed under 192.168.1.2. Then few minutes later it's not longer on the list of attached devices.
However, when I ping 192.168.1.2 in a web browser I can talk to the printer. Until it drops off line... which is typically 3 to 5 minutes after re-booting printer.
**Seems much more stable now that I have removed the satellites from the picture. But after 30 minutes It still dropped offline, and I was unable to ping the printer via a web browser at 192.168.1.2. Rebooting the printer fixes the issue.
Does this happen with both wireless and wired devices?
Just the printer drops wifi, but I have not tried to hardwire the printer.
What channel configurations are currently set on the router?
2.4 manually set to channel 1 (IoT set to 2.4 only)
5 and 6 GHz set to AUTO
Try disabling the following and see: Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
All these were already disabled during my trouble shooting process.
Try connecting the printer to the IoT network SSID configuration.
The printer has always been connected to the IoT network. Which is set 2.4 GHz only.
You might be confusing "static route" with "static address". There is no need to create a static route for a reserved IP address - and if you don't know what you are doing you can really mess up your network routing. You reserve an IP address on the advanced->LAN Setup page.
FWIW, a static route is used to tell the router how to reach a network it otherwise doesn't know how to reach. That is, a different subnet.
Static Routes should not be used for the printer. Not needed or required. Remove this configuration.
Make sure the printer is set for DHCP/Dynamic IP address configuration.
Try connecting the printer to the main wireless network as well.
For that size of home, the RBR unit and just one RBS satellite is enough.
25 feet is too close between the RBR and this closer RBS. Try the RBS out at 30 feet or a bit more.
Try connecting the printer over ethernet as I believe the printer has a ethernet port.
Make contact with the printer Mfr as well since this is there product and seems to be the only device having issues.
Try connecting the printer ot the IoT network SSID configuration.
