Markie610
Sep 23, 2024Tutor
5Ghz wifi not working
Hi all, Im having an issue with AX6000 router. Couple of days ago my 5ghz wifi network suddenly disappeared, i tried rebooting the router but it didn't help. I've reached out to customer sup...
michaelkenward
Sep 23, 2024Guru - Experienced User
Disappeared from what? All devices?
Did you see this:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
Unless you have disabled Smart Connect there is just one SSID for 2.4 and 5 GHz.
If a laptop, for example, can't see the router that would mean that all WiFi is dead.
What do the LEDs look like? Is the WiFi LED on?
What modem/gateway/ONT sits between the router and the Internet?
Just another user with time on their hands.
