Markie610
Sep 23, 2024Tutor
5Ghz wifi not working
Hi all, Im having an issue with AX6000 router. Couple of days ago my 5ghz wifi network suddenly disappeared, i tried rebooting the router but it didn't help. I've reached out to customer sup...
Sep 23, 2024Guru - Experienced User
1. What router do you have? AX6000 is a speed, not a model.
2. Your description doesn't make a whole lot of sense. Some devices can see it but when connected get "connected, no internet" while others can't see it at all? That doesn't make sense. If it wasn't broadcasting, nothing could see it. If its broadcasting and you're connecting devices to it but getting connected, no internet, then it tends to indicate a configuration error. Clarity helps here. Plus screen snips of the routers wifi status page and/or something like insidder or acrylic wifi scanner.
3. What modem/gateway is the router connected to?
Markie610
Sep 23, 2024Tutor
Hi all,
1. The model is RAX80
2. Current set-up was working fine for 2.5 years, Wifi 5ghz seems to be online in the admin portal but even though i can connect to it the connection is dropped within 30mins of connecting. Previously it was either not visible at all or when visible devices could not connect. I've performed one more hard reset today which allows devices to connect but as i mentioned connection is lost after approx. 30 mins
Here is the 5ghz set up:
The router is connected via cable straight to the internet outlet.
Wifi LED is enabled and 2.4ghz network works without any issues. Smart connect is disabled
- plemansSep 23, 2024Guru - Experienced User
Markie610 wrote:
Hi all,
The router is connected via cable straight to the internet outlet.-----this still comes from something. Whether its an ONT or some type of gateway, there is still something its connected to as the RAX doesn't have any modem capability.
Go in and set your "up to ****" speed from up to 4800mbps to 2400mbps. You're using dfs channels. Not sure how frequently they're used in EU (since it looks like your region) but if a new weather/radar is broadcasting in your area, it could be causing issues. You'll also want to check whats supplying internet. Double nats can cause all kinds of random issues. Its usually not a problem but it could be causing your "connected, no internet' issue.
and after you change it to up to 2400mbps, make sure to select a non-dfs channel for your region.
- Markie610Sep 23, 2024Tutor
Hey, changed it to 2400mbps, selected channel 44 is non-dfs channel. Will report back see if it helps!
changing to speed to be set to 2400mbps did help, what could be the reason behind it anything i can do to change it back to 4800? Previous setting was working fine for 2.5 years 😐
- FURRYe38Sep 23, 2024Guru - Experienced User
Since you changed to a non DFS channel, try raising the speed back to 4800Mbps to see if the problem appears or continues to work for you.
