Markie610
Sep 23, 2024Tutor
5Ghz wifi not working
Hi all, Im having an issue with AX6000 router. Couple of days ago my 5ghz wifi network suddenly disappeared, i tried rebooting the router but it didn't help. I've reached out to customer sup...
Markie610
Sep 23, 2024Tutor
Hi all,
1. The model is RAX80
2. Current set-up was working fine for 2.5 years, Wifi 5ghz seems to be online in the admin portal but even though i can connect to it the connection is dropped within 30mins of connecting. Previously it was either not visible at all or when visible devices could not connect. I've performed one more hard reset today which allows devices to connect but as i mentioned connection is lost after approx. 30 mins
Here is the 5ghz set up:
The router is connected via cable straight to the internet outlet.
Wifi LED is enabled and 2.4ghz network works without any issues. Smart connect is disabled
Sep 23, 2024Guru - Experienced User
Markie610 wrote:
Hi all,
The router is connected via cable straight to the internet outlet.-----this still comes from something. Whether its an ONT or some type of gateway, there is still something its connected to as the RAX doesn't have any modem capability.
Go in and set your "up to ****" speed from up to 4800mbps to 2400mbps. You're using dfs channels. Not sure how frequently they're used in EU (since it looks like your region) but if a new weather/radar is broadcasting in your area, it could be causing issues. You'll also want to check whats supplying internet. Double nats can cause all kinds of random issues. Its usually not a problem but it could be causing your "connected, no internet' issue.
