Cbmarsh39's avatar
Cbmarsh39
Follower
Aug 22, 2025
6ghz light off
I noticed recently the 6 ghz channel isn’t lit up anymore on my router. I can still connect to it, but in the app it now says unknown network for a device that’s connect to the 6 ghz channel (it’s a new iPhone 16 pro that is WiFi 6E compatible). Any ideas on why this is happening?  I’ve messed with a bunch of the settings on the admin webpage with no luck in a fix. Thanks!
1 Reply
  • FURRYe38's avatar
    What model router is this?
    Is the check box for enable 6Ghz radio uncheck in the routers WEB page UI? Basic tab or under Advanced Tab/Advanced Wireless Settings...
    Try a factory reset and setup from scratch and see if it re-enables?
    Is the 6Ghz signal seen by a wifi analyzer at all?
