AClient
May 01, 2021Follower
A strange issue with RAX35 connection quantity
Just recently, I've encountered a really strange issue with my RAX35 router.
I could not get an Internet connection even on my wired computer.
Everything was OK with my Modem, my Router. No issues whatsoever, but NO INTERNET.
I've started checking for any issues on my iphone Netgear app.
I've discovered that I had 27 "devices" connected to my Network.
WOW!
I've started checking EVERY device I have in the house.
And I've discovered that it's a BUG in the NETGEAR ROUTER.
It's a BAD BUG that needs to be FIXED!
Let's start.
When I connect my iphone to my local network, RAX35 registers it.
OK.
After some break in using the local network/Internet on my iphone, I need to use the Internet on my iphone,
RAX35 registers it as a NEW DEVICE(???).
It means, that during a few hours, RAX35 has about 6 or 7 DEVICES from just one my iphone.
When my wife starts using her iphone, RAX35 starts registering it as NUMEROUS DEVICES.
When you add a laptop, ALEXA, a TV, etc..., RAX35 immediately exceeds the device count.
I've learned how to deal with that nasty bug.
I open the NETGEAR app on my iphone and start deleting those devices, clearly marked as "OFF-LINE".
I have never had that kind of issues with my older NETGEAR routers.
Sort By
> [...] RAX35 [...]
Firmware version?
> Let's start.
Yes. Now that you've decided what the cause of the problem must be,
let's look at the actual evidence.> After some break in using the local network/Internet on my iphone, I
> RAX35 registers it as a NEW DEVICE(???).Perhaps the router sees it as a different device because it presents
itself as a different device.https://support.apple.com/en-us/HT211227
Which "older NETGEAR routers" did you use with devices running iOS
version 14.x?- ANewUserAspirantMy router is RAX35v.2
My older one was AC2350.> My router is RAX35v.2
> My older one was AC2350."AC2350" is a speed, not a model number, and the firmware version
mystery is still a mystery, but the real question is whether you were
running iOS 14.x with it.> https://support.apple.com/en-us/HT211227
Did you read it? Did you try to "turn off the Private Address
setting for that particular network"? Or is at least one of us wasting
his time here?
