sanketprajwal's avatar
Dec 07, 2022
Antenna Part Number: NETGEAR RAXE500
Hi ,
I am trying to get the Part Number for Antenna Pigtail - SMA Connector to Rewire the Antennas of RAXE500.
It would be helpful if I could get the part number. Please let me know.
Thanks,
Prajwal
    • sanketprajwal's avatar
      sanketprajwal
      Initiate
      Thanks for the Info. However, I couldn't find the exact Part Number for the Antenna Pigtail from the Documents
      • plemans's avatar
        Guru
        I don't think you will. Netgear doesn't even sell replacement antenna's for the routers with detachable antenna's so I highly doubt you'll find them for the ones integrated into the wings on the raxe.
