zognorf's avatar
zognorf
Apple services suddenly not working with RAX80
Sometime as of the past week or two, no Apple device connected to my wifi is able to stream data. That means, Apple Music does not work, nor does Apple TV, software updates, App Store downloads, etc. The best I can figure is that Apple changed something involving security that Netgear has neglected to roll out in a firmware update, leaving me somewhat out of luck.
I'm not really sure who I should be more pissed at, at this point. Would be nice if anyone here has any clue as to what one can do, if anything can be done at all besides buy a different router. This thing is barely 3 years old and was certainly not the cheapest, so I expected better.
  • michaelkenward's avatar
    michaelkenward
    Apple is famous for changing things and not telling anyone else in the industry what it has done. That makes it hard for Netgear, and anyone else, to produce "forward compatible" devices. And the market for crystal balls is a mug's game.
    Have you approached Apple for help?
    Did you find this?
    NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
    Just another user with time on their hands.
    • zognorf's avatar
      zognorf
      I tried the disabling private IP and so-on as per the link you sent, but that didn't solve the issue. I should add that the official Apple Music app on Windows 10 also has this issue, so I suspect whatever "security changes" they implemented are also present there. Using Cider or any other web-based Apple Music interface works though (but with worse audio quality).
      Apple basically said I need to update the router. I can't blame them on that front, it is clearly a router issue, but I am using the current firmware version so...yeah, not sure what to do.
      • FURRYe38's avatar
        What iOS is on the Apple devices?
        What FW version is actually loaded on the RAX router?
        What channels is the router using? Try 1 and 40 or 11 and 48.
        What security modes is the router using? WPA2 and AES is recommended...
        Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
