TexanJohn's avatar
Jan 21, 2021
AX Recommendation
Hello,
I'm experiencing some intermittent issues with our internet service. I think it might be problems with our AC1900 (R7000) that is 7 years old.
I was looking at the AX models.
We have 3 TV's (2 are 4K), 3 phones, 1 gaming box, 1 occulus, and 4 computers, thermostat, ... all of which can be in use at any given time. Gaming is not a big item/consumption in our house.
Recommendations?
We seem to get by on a 200Mbp plan from Spectrum (to guage our capacity needs).
On the low end I see something like the AX1800 which seems like an improvement over our current unit. Are the $300+ units needed necessary or worth it?
Thanks.
  • plemans's avatar
    How big is your home?
    What are the interior walls made of?
    Depending on the size, the $300 might be better invested in a system like the triband orbi's versus going up to AX.
    AX is great but for a 200mbps, a decent orbi system will easily max that out and potentially provide better coverage. (i'd avoid the dual band orbi's)
    • TexanJohn's avatar
      TexanJohn
      Tutor
      2700 sqft, standard 2x4 with sheetrock for the walls
      Because of the layout/length, currently I have two AC1900's. Each on one end of the house with the far one operating in AP mode (recieving a hardwire connection from the main AC1900).
      I have concerns my main AC1900 is aging/failing, so possibly looking at a newer unit.
      I will research the tri-band orbi's. Thanks.
      • plemans's avatar
        The r7000 has had firmware issues for a while.
        Some have revived them by using version 1.0.9.42 of the firmware. If you try it, install it over a hardwired connection, then do a factory reset, and a clean install (not from backup). Might be worth a shot as the r7000 should easily handle 200mbps.
