BostonRob777's avatar
Feb 20, 2022
AX12 RAC 200
I am completely frustrated over this damn device. I lost all my wireless channels. Nothing is showing up. I’ve rebooted. Upgrade the firmware. This thing is a piece of crap.
  • What actual device do you have? AX12 isn't a mode. And there isn't an RAC model. Maybe you mean the RAX200?
    Is the wifi not broadcasting at all?
    did you try pushing the wifi on/off button for 2 seconds?
    • BostonRob777's avatar
      BostonRob777
      Tutor
      thank you for the reply. I had the model number wrong - RAX200 Nighthawk AX12
      Wifi is broadcasting but the Netgear Nighthawk app no longers shows an expanded menu where you have parent controls and the ability to turn devices on/off. All this is now gone.
      • plemans's avatar
        Guru
        so wifi is working? just having app issues with parental controls/access controls?
