ChirpChirp
Aug 28, 2023Follower
AX1800 RAX10 - Constantly disconnecting and slower speeds
After having the same wi-fi router for several years, I recently upgraded to the AX1800 RAX10. It was working very well for the first two months. It is now disconnecting quite a bit and requiring a r...
microchip8
Aug 28, 2023Master
Disable DoS protection? You're not missing much since 95% of it is false positives.
