daviddilley
Nov 15, 2021Aspirant
AX3600 Mesh will not reconnect to modem after power outage
The mesh router will not reboot and connect to modem after a power outage. Need suggestions and help
Sort By
1. what mesh is it? AX3600 is a speed
2. what firmware is on it?
3. what modem are you connecting to?
4. what are the led's on the router doing? (color/blinking/etc)
- daviddilleyAspirant
Tri-band Mesh Wifi 6 System. Connects to the new Spectrum modem. After a power failure the modem boots up but the Mesh does not. The mesh has an amber light and does connect if I push the buttom on it to reboot.
Problem is, the Mesh Wifi is at our summer residence and I am 1,500 miles away. I have a friend that is going to go in and plug it into a UPS to see if this helps
daviddilley wrote:
Tri-band Mesh Wifi 6 System.-----Still doesn't tell us which model. There's several models.
Connects to the new Spectrum modem. ---again, still not a model.
After a power failure the modem boots up but the Mesh does not. The mesh has an amber light and does connect if I push the buttom on it to reboot. ---some devices are more sensitive to the order in which they need to be booted. Some need the modem booted for a couple minutes before you boot the router.
Problem is, the Mesh Wifi is at our summer residence and I am 1,500 miles away.----that is a bit of an issue I have a friend that is going to go in and plug it into a UPS to see if this helps---certainly might be your best option.
