mjz's avatar
mjz
Apprentice
Dec 31, 2019
AX4 - RAX35 How to enable led "blinking"
I tried setting the LED lights on my router to "enable blinking" to show traffic, but there is no such setting on this new router?
There are only two options - turn off all leds or disable blinking. Only one or the other can be selected.
Is this a firmware bug?
Thanks
    • mjz's avatar
      mjz
      Apprentice
      Hi Christian,
      No LED's are blinking even though I am sending traffice through the router.
      LED's are 'lit' up showing that my wireless radio's (2.4 & 5.0 ghz) are on as well as power and Internet connection. All green.
      Router is working, just no blinking is possible apparently. The web interface does not have a "enable blinking" option. I can only 'disable' blinking or turn off all LED's except power.
      Strange ...
      • Christian_R's avatar
        Christian_R
        NETGEAR Employee Retired
        Mjz,
        Thanks for providing a screenshot. I have sent you a message.
        Christian
