tadigiacomo
May 04, 2022Guide
AX4300 (RAX45) as Access Point Seems to Block duckduckgo
I have an AX4300 set up as an Access Point. The main router is an AC1750 (R6400v2). When I try to access duckduckgo.com while connected to the AX4300 via WIFI the browser says it cannot be reached, and the error is ERR_CONNECTION_TIMED_OUT.
When I connect via the AC1750 WIFI I have no issues. When connected to an Edimax AC750 access point I am replacing and a hardwire connection I am also able to access the site. This happens in Chome from both a Samsung S20+, which is WIFI 6 capable, and an HP laptop which is WIFI 5.
I've played around with different settings, but to no avail. Does anyone have any idea what the issue can be? Thanks!
Try enabling IPv6. I've seen more devices defaulting to ipv6 for their first dns inquiry. maybe its causing an issue
In AP mode, the RAX shouldn't be doing any dns/hcp/etc. Thats all forwarded on.
Do you have IPv6 enabled on the R6400?
what firmware is on the R6400?
If you don't mind my asking, why are you using the R6400 as primary and the RAX as AP?
The RAX has a much more capable process/specs. In AP mode, its not getting close to using its capabilities.
The R6400v2 firmware version is V1.0.4.122_10.0.95. IPv6 is disabled.
A bit of a long story, I bought the RAX45 to replace the R6400v2, then would use the R6400v2 as an access point. I come to find out that I didn't read the the RAX45 data sheet completely, or I would have learned that Netgear Smart Parental Controls are basically useless without a subscription. I use CIrcle with the R6400v2 without a subscription mainly for some content filtering. So, I left it in place as the router until I decide what I am going to do regarding a subscription. I may just have to bite the bullet. I agree, it should be the main router. Thanks for your reply!
