Feltenix
May 29, 2023Aspirant
AX5400 RAX50v2 Bridgeing
I just got the AX5400 a couple of hours ago. I specifically got it for the wireless bridging capabilities. There was nothing in the listing or on the packaging to indicate that this was the RAX50v2. I specifically got it from the Netgear section on Amazon. On the webpage for the wireless bridging I saw that RAX50v2 does have support for wireless bridging. Is my only option to return the router? Or are the they firmware compatible and I can reflash the RAX50v2 with the RAX50 firmware?
Do you not see wireless bridge mode on the router WEB UI?
No.
What does the label on the router say? If it doesn't say V[something] it is V1.
Or are the they firmware compatible and I can reflash the RAX50v2 with the RAX50 firmware?Usually, no.
Netgear provides the same manual for each version. That maybe a mistake, given Netgear's performance on documentation. That has a section Enable bridge mode.
There are rarely significant feature changes between hardware versions.
Which firmware version do you have on the router. ("The latest" isn't reliable, only the number will tell.) Updates have been known to mend things that were bust in the original release.
- FeltenixAspirant
Attached is a screenshot of what I see when I login to the router. Following the online guide Advanced > Advanced Setup > Wireless Bridge, but it isn't there.
If you don't see Bridge mode under Router Mode/AP Mode then this version of the RAX50 doesn't support it. There was a HW change from what I was told and FW versions are different between v1 and v2. v1 FW can't be loaded on v2.
