Feltenix
May 29, 2023Aspirant
AX5400 RAX50v2 Bridgeing
I just got the AX5400 a couple of hours ago. I specifically got it for the wireless bridging capabilities. There was nothing in the listing or on the packaging to indicate that this was the RAX50v2...
May 30, 2023Guru - Experienced User
If you don't see Bridge mode under Router Mode/AP Mode then this version of the RAX50 doesn't support it. There was a HW change from what I was told and FW versions are different between v1 and v2. v1 FW can't be loaded on v2.
Feltenix
May 30, 2023Aspirant
Thanks for the help. It looks like the only solution is to return it and buy something other than a RAX50 as it will likely be a v2 as there is no indication of not getting some other rev of the product on the box or advert. I wonder if there are any other hidden revisions out there. Or if I should just go old school and use a wire.
- plemansMay 31, 2023Guru - Experienced User
what are you actually trying to do?
Might help to know that and we might be able to recommend something versus just going straight to bridging a router.
For example, many of the extenders have ethernet ports you can connect a PC to and use them as extenders.
Or switching to a mesh system and hardwiring the device to one of the satellites.
