Feltenix
May 29, 2023Aspirant
AX5400 RAX50v2 Bridgeing
I just got the AX5400 a couple of hours ago. I specifically got it for the wireless bridging capabilities. There was nothing in the listing or on the packaging to indicate that this was the RAX50v2...
Feltenix
May 31, 2023Aspirant
Attached is a screenshot of what I see when I login to the router. Following the online guide Advanced > Advanced Setup > Wireless Bridge, but it isn't there.
michaelkenward
May 31, 2023Guru - Experienced User
I'd expect to see it in either the Router / AP Mode slot, which is where it is on my R7800, or, if the manual is correct, in Wireless Settings. (That's not to be confused with the VLAN / Bridge Settings bit, which is something else.)
Looks like another Netgear manual that needs an update for the new hardware version.
