revenantananias's avatar
Aug 08, 2024
ax5400 USB3 not working
firmare is 1.1.4.28
the usb3 is not working. of course, I am a month out of the yearly warranty. this is the second time this has happened to me with this same router. are these prone to failure, or am I just lucky? I am not in the mood to reset the whole thing to *hope* it starts working again. is there a fix, or do I write off this company for making routers that need to be replaced yearly for over $200?
  • revenantananias's avatar
    revenantananias
    Aug 11, 2024
    I have no idea why, but I wanted to make sure that the laCie hard drive was indeed working before I went through the inexplicable joy of factory resetting the router. My Mac saw it and I was happy with that, I plugged it back into the router before I was about to do the factory reset and was amazed that the usb light on the router turned on. I then checked the network and lo and behold the drive was there.
    no sure what that was all about, but I am happy it is over.
    thanks.
  • michaelkenward's avatar
    michaelkenward
    Not working doesn't tell us much. Can you provide more details?
    Which USB3? Storage? Printer? Several devices?
    Just another user with time on their hands.
      revenantananias
      sorry, it is a hard drive. the usb light for usb on the router does not turn on anymore, but the drive works fine if plugged into a computer. I even tried another hard drive in the usb3 slot to be sure. both work on my computer, neither turn the light for usb on the router. I have restarted the router twice (no factory reset)
