aalexandrebeta
Mar 03, 2019Master
AX6000 RAX 80 print server absent!!!!!
Why is there no print server feature on that router?
It is like if a ferrari was not provided with reverse gear!!
What is wrong with that picture????
schumaku
Mar 04, 2019Guru - Experienced User
Because it's not in the specifications, it's not implemented, not part of the offering, not part of the product - nothing to complain.
Remind me to write a complaint letter to Elon Musk that the Tesla X hasn't.any differential locks while my 4x4 Pinzgauer has three.
aalexandrebeta
Mar 04, 2019Master
This is not on specifications, not implemented not an excuse, a 20 Y/O modem routeur is still able to do thet so, so it should be implemented directly to the standard specifications period.
I complain because it should go like the safety belts on a car!!!!
A good old cheated software VW is greener than a Tesla X!!!!!
The more tech you put in a car the less reliable it is!!!
- schumakuMar 04, 2019Guru - Experienced User
The RedyShare USB print feature is almost obsolete and given up by Netgear. Look at the poor maintenance of the required code to run it from Windows or (even worse) MacOS. A nightmare on it's own.
Today's low cost printers have Ethernet ports or at least a WiFi client.
Time to abandon the incomplete and unreliable USB ReadyShare for crappy USB disks, too: A router isn't a NAS. Why you ask? Netgear failed to keep things up to speed - WSD (WS Discovery) is stil not implemenented, however it's the Windows 10 set industry standard.
Back to the roots of what a router should be and have: Configureable firewall rules for Internet->LAN, provide services like a local DNS, ... and much more. This is what I want to see today on a consumer router. Not legacy features like NetBIOS discovery/name resolution or USB port sharing.
The more garbage features Netgear does put in a router the less reliable it is!!!
Proof enough - just look around these communities. It's safer for Netgear to go back to the roots, removing what's not required on a router.- antinodeMar 04, 2019Guru
> Because it's not in the specifications, [...]
Which "the specifications"? I seem to see it in the RAX80 Data
Sheet:http://netgear.com/images/datasheet/networking/wifirouter/RAX80.pdf
Sharing
READYSHARE (R) USB ACCESS-Wirelessly access & share
USB hard drive & printer via two (2) USB ports
Which part of "& printer" is unclear (or absent)?
> Netgear. [...]I'm willing to stipulate that all Netgear USB-related file- and
print-sharing software is garbage, but that doesn't seem to stop Netgear
from advertising it.- aalexandrebetaMar 04, 2019Master
antinode you are right and it makes me really agry because this feature is a basic stuff which is included in obrands router portfolio!!!
schumaku Just order a brand new car and see what is your reaction if there is no AC and GPS even if it is in the contract!!!!
