aoz's avatar
aoz
Tutor
Aug 29, 2022
ax6600 mounting, best position to do this
what is the best orientation to wall mount the ax6600?  with the wire ports facing UP?  or with the wire ports facing DOWN?  or  the wire ports facing sideways?
if i mount them DOWN, it easier for me to access them.  and sideways would work.  but i want best orientation for signal??
thanks
