jingstar's avatar
jingstar
AX6600 Rax70 once connect Seagate 8TB HDD for Readyshare, router reboot itself constantly
I have a Nighthawk AX6600 Rax70, used without any issue at all, however, whenever i connect a hard drive to its usb3 port (HDD has its own power cable), tried Seagate 3TB, Seagate 8TB, it always constantly disconnect itself, usually every hour will internet completely down, and reboot itself.
  • I have checked that time that i have the latest version which is Router Firmware Version V1.0.15.146.
    when i connect Seagate 8TB HDD to router's usb3, occassionally router will frequently disconnect itself from internet, that is the indicator turns to orange from white color, and i just simply doesn't have internet, need to hard restart router again to get my internet back again, but after about half hour, it losts internet again. However, once i dont connect HDD to the router, everything fine, no disconnection at all.
    • FURRYe38's avatar
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
