dmystic1
Feb 03, 2019Apprentice
Bad bufferbloat with RAX120
Im getting a D rating of bufferbloat during the Upload with the RAX120. Is this solved with a gaming specific router only?
microchip8
Feb 03, 2019Master
No it's not. I use an R7800 and get a solid A and A+ on bufferbloat. In the past I had always D. Then was forced to changed modem (due to internet subscription upgrade) and now get A/A+ on the tests. Bufferbloat can be caused by many things, not just the router used
- dmystic1Feb 03, 2019Apprentice
When I had cable internet I could change the modem, now with fiber that is not an option.
- michaelkenwardFeb 04, 2019Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
- dmystic1Feb 04, 2019Apprentice
1.0.0.64 there is no newer firmware and there is no modem, Im on fiber and the modem is a Optical Network Terminal.
