dwaynek's avatar
dwaynek
bug report: firmware 1.0.4.102 for RAX40 doesn't allow ssid/password to be changed
the latest firmware 1.0.4.102 won't allow me to change ssid/wifi passwords even after repeated resets.
I finally rolled back to a previous version which works fine.
  • FURRYe38's avatar
    Did you factory reset the router and setup from scratch after v.102 was loaded?
  • Hi dwaynek ,
    Did you use GUI or Nighthawk APP to config the Wi-Fi setting ?
    If you used Nighthawk APP, which app version did you use ? iOS or Android ?
    Thanks.
