Topper2k's avatar
Topper2k
Can I use an MR60 as a satellite?
I have two Nighthawk MR60 mesh routers. Is it possible to use one as the router base station and the other as a satellite?  And if so, how?
  • schumaku's avatar
    schumaku
    Not officially. Some hacks appeared in the net however.
    • Topper2k's avatar
      Topper2k
      Thanks. I've found some instructions on how to make the mr60 work as an access point. Is that what you mean? That looks like it requires a wired connection and a different SSID.
      Can you point me to instructions to make it work like a satellite? I haven't had any luck finding them.
