chen123's avatar
chen123
can not access router and internet
I have a RAX40V2,There have been frequent problems recently。
The problem is “can not access interent and also can not access router”
When the problem occurs
1 The led on the router are normal,but can not access internet
2 wifi can be searched through my phone(2.4G ,5G)
3 can not connect to router(use phone or computer)
4 router address is 192.168.4.1,ping 192.168.4.1   failed
5 power restart,it return to normal
the router works well for more than one year,The problem occurred in the last week or two。(Once every 2-3 day)
Maybe it has something to do with my modification of some configurations
what i have done
1 A mobile hard disk is plugged into the router(i want to use readyshare)
2 i have another router(R6220,address is 192.168.10.1),is connect to RAX40 (lan),it is a subrouter before,but  change  to be an  access point(because i want all devices are in one LAN)。
how do I troubleshoot it
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    • chen123's avatar
      chen123
      thanks for your reply
      i think the device and network connected to the wlan port are OK。
      The biggest problem I encountered was that I couldn't access to the router  。so i can not find out what happens
      • FURRYe38's avatar
        Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
